Mini Z Racer
Old 05-27-2002, 12:19 AM
MYNAMEHERE
Default Mini Z Racer
I am sure that many of you out there have a mini z but how many of you like me are experiencing radio troubles. Well I am, and if any of you could help i would greatly appreciate it. I just swapped out the stock motor for an X-speed, not for the speed but for the more flexible wires, and ever since then i have not been able to control the car and it will do some crazy stuff, like twitching steering and every once in a while slamming into reverse as i try to accelrate after braking.
Old 08-27-2003, 02:23 AM
Accident
Banned
change the batteries, I dont know if its the same but I was playing with my T-Maxx today and all of the sudden it started acting weird - all the servos were jumping like crazy - I replaced the batteries in the truck and the control and the problem was gone. dont know - worth a try...
Joe
Old 08-27-2003, 02:26 PM
dg2b
Check the capacitors and make sure it has a good solder on them. Also, as Accident mentioned, check the batteries.
If the capacitors on the x-speed is good, put back the stock motor and see if the issue is still there. If the stock motor eliminates the issue, the x-speed is no good.
