Yellows Stingray VS PCM Av8r
AB, CANADA
i have read my reading and for aa 12lb engine i found 2 good platforms for a aircraft i was woundering if i could get some feed back on the stingray and the Av8r
AB, CANADA
RE: Yellows Stingray VS PCM Av8r
they are both under 400 but i was woundering if the stingray flew like the bob cat and the roo or is it going to be quite a bit different becausse of less wing sq inc
Hello.
The Y/A Stingray is no trainer, and does not fly like a Roo. It is quite fast with a 12 lb turbine.
I have not flown the AV8R, but from what I hear it is a trainer. So, it all depends on your skills and needs.
Just my 2 cent.
Just my 2 cent.
My Feedback: (10)
If you can handle a sport, low wing prop plane or pattern style plane, you will have NO trouble with the AV8R at all. I know it can EASILY take off from a semi-rough grass strip in under 300 feet, and land it in under 100 feet.
The Stingray is going to be a lot faster in the air, but will require a larger runway to take off and land it, not sure about the longevity of the retracts on a grass strip either... I know it wouldnt be an option at my club's field whereas the AV8R is perfect.
AJC
AJC
