Cap X - CG
Cap X - CG
Hey Chip,
The reference for the " Center Of Gravity " was left out of the
Temp Manual for the Cap X. Where is the CG located for this plane?[]
Stick2K
Stick2K
My Feedback: (8)
RE: Cap X - CG
3-3.5 inches back at the tip. Basically if you are running any glow engine put the battery in front of the tank, and with the gassers it goes in the radio compartment.
Chip
Chip
ORIGINAL: Stick2000
Hey Chip,
Stick2K
Hey Chip,
Stick2K
My Feedback: (113)
RE: Cap X - CG
Here goes....a dumb question. CG is 3" to 3.5 " from the tip? This must be measured from the wing tip and not the leading edge which makes it 5.5" to 6" back from the leading edge at the fuselage. Otherwise my Cap-X with a 40 cc Fox needs 2.5# on the nose. Please clarify.
My Feedback: (8)
RE: Cap X - CG
[q
At the tip is correct.
Chip
uote]ORIGINAL: arfdog
[/quote]
Chip
[/quote]
