Zenoah G26 - RF interferrence
Banned
Hi,
a friend in thye club I am in has a Modeltech Dragon lady powered by a Zenoah G26. He has suffered a few hits whilst flying and subsequent investigation points to RF interrence from the ignition system of the G26.
He has shielded the spark lead with briading and I had suggested making sure the case of the motor and battery were at same potential.
throttle linkage is plastic as is the flex rod.
Can anyone shed any further light on what he might try to cure this?
thanks
Peter
[email protected]
thanks
Peter
[email protected]
been there done that, make sure that all kill switch wires or any ignition wiring is at least 12 inchs away from all radio leads and reciever and any radio parts.
My Feedback: (23)
You said something like "...make the engine case and battery ground at the same potential...". Since the G-26 doesn't have an electronic ignition, and therefore no battery of it's own, I assume you mean the receiver battery. Herein lies the problem. You absolutely positively cannot join the case of the engine to any part of the receiver circuitry, including the battery. This will bring RF noise from the engine directly to the radio system and it will give you problems that cannot be corrected.
If it were me, I'd remove the braid from the high tension (spark plug) lead and disconnect the engine case from the receiver battery ground. Make sure EVERYTHING associated with the engine is at least 12" from EVERYTHING associated with the radio system, This includes batteries, switches, kill switch, antenna, servos, EVERYTHING!
I have used 2 separate G-26 engines on 2 different planes and followed the above rules and there's no problems. If problems persist, you may want to investigate the radio system itself.
Banned
RE: Zenoah G26 - RF interferrence
I am puting on a g-26 on a 1/4 202 in the book it said pressure fitting nipple dos it need it?????? if not what do i do with the one that go`s to the pipe
my email is [email protected]
ps.. if some one can help me ....i thank you
Make sure the spark plug is a resistor plug; should have an R in the part no. Also, if there is a lot of carbon build up in the engine and on the plug interferance can occur. Mr. Pettit gave good advice above although I often get by nicely with much less than the recommended 12 inch seperation. Also make sure there is no metal to metal joints anywhere on the plane that can vibrate or rub together. Check all flying wires, landing gear braces etc.
