World Models P40
My Feedback: (13)
RE: World Models P40
Dear Woody;
The W.M. P-40 is a way stand off scale model. The retract system is not very good, and I never liked the system they use. On the other side of the coin, the model flyies very well and suprisingly fast with a hot .46. It is larger then the W.M. P-51, but flies better too. The company sprayed paint over a shrink covering to get the camo paint job...and it is durable. My only falt is the landing gear...it is weak, and toss out the tires and get some good Du-Bro units in placed.
Have fun...
Soft landings always,
Bobby of Maui
Have fun...
Bobby of Maui
My Feedback: (24)
The WM P-40 is not very scale looking:
I agree with Bob about the landing gear. The plastic mechanisms are weak. The plane comes with tiny main wheels. If you don't grease your landing on a grass runway, you will snap both of the retract mechanisms. I flew the plane once, and it didn't have a nice stick feel to it.
Thanks guys,
Mine is yet to be assembled. I don't like the retracts that are in it anyway and besides, the wheels as installed on the model are facing the wrong way for a P40 (They face in rather than out as on the real thing.)
And yes, the ones in the kit are far too small for grass. The wheel wells look as if they can accept bigger units anyway.
I fly off rough grass, nothing as good as your photo's Richard, (my club shares the field with farm stock) so maybe some epoxy modifications, to make the gear permanently "down", might be the answer for me. Failing that , some decent Robarts or Du-Bro units as you suggest Bob.
Did either of you have to add any weight to the front or back to get the correct C of G?
I have a Saito .65 4 stroke reserved for mine and your info will assist me when the building process finally starts.
My Feedback: (13)
I had one. One of the servos failed after a couple of years and took the plane with it. It took a ST 75 to pull it around at the altitude here (3500'). It actually landed fairly easily. I have the same comments about the gear. I broke three or four right retract cases. Then had to buy a pair to get a replacement. I had problems with the wire from the bellcrank to the gear. The wire is weak and at an angle to the retract. (Unless their design has changed). I had a continual patch on the top of each wing where I had to go in and fix the wire.
I thought the plane itself was pretty stout. I had to add a few ounces of weight in the tail with the ST 75 in the nose.
Brian
Brian
