DA50 break-in and ignition battery
Old 03-05-2004, 02:03 PM
nonstoprc
My Feedback: (90)
nonstoprc's Avatar
Default DA50 break-in and ignition battery
I just talked to DA and gor the following two piece of information:
It is better to break in DA50 in the air than on the ground
It is OK to use 4 or 5 cell Nicad or Nimh for the ignition battery. No regulator is needed.
I wonder if somebody is doing it differently.
Old 03-05-2004, 06:19 PM
deputydog
Default RE: DA50 break-in and ignition battery
All gas motors benefit more by breaking them in airborne. Because the breakin period is a long duration it does no good to run them on the ground(You dont idle your new car in the driveway for 4-5 hours do you?).
Nicad and Nimh have been the standards for a long time. The electronic ignitions are pretty tolerant of either a 4.8 or 6v pack. Only since the Lithium's have shown up is there a need for a regulator. The DA-50 is a great motor!(I love mine!!!!!!)
Old 03-05-2004, 07:34 PM
GoeKeli
My Feedback: (18)
GoeKeli's Avatar
Non-stop,
I'm on my 2nd gallon and loving it. I am trying to keep myself from the needles because it dies on idle and I need a low idle because the plane walks. I just run a 1000 mah nicad and fly 8 15 minute flights and the most i've recharged was 600 mah at the end of the day. This is one kick-***** engine and I am very happy with it. Did you leave your throttle spring on?
Joe
Old 03-05-2004, 09:11 PM
Antique
Antique's Avatar
Why are you afraid to re set the low speed needle ? You think DA has ESP and knows all about your prop size and atmospheric conditions ? a gasser should idle at 1400 rpm all day long and still transition perfectly...Needle settings are not voodoo, experiment a little, you just might like the results..
If you want it to die, just set the low speed idle for about the middle of the throttle trim and kill it that way...
Old 03-05-2004, 11:46 PM
GoeKeli
My Feedback: (18)
GoeKeli's Avatar
Your right Ralph. I'll get to it monday. [8D]
Joe
Old 03-15-2004, 11:05 PM
nonstoprc
My Feedback: (90)
nonstoprc's Avatar
I plan to remove the tiny throttle spring as it will make the throttle servo work hard. Have you done that? Do you even test run the motor on a stand? I am debating myself if that is necessary.
Old 03-16-2004, 08:06 AM
stomper
My Feedback: (20)
You can unhook the throttle spring from the throttle arm but do not remove the spring from the shaft!
Old 03-16-2004, 09:20 AM
Mike Bogh
My Feedback: (14)
I have read that it is better to leave the spring on...doubles as a failsafe, and it somehow keeps the butterfly from getting all beat up.
I was going to unhook mine but I posted a question yes/no and the consensus by those whom I hold in high regard said leave it hooked up.
So I did.
Doesn't seem to affect how it runs...
Old 03-16-2004, 10:54 AM
Texas 3D
Texas 3D's Avatar
why would you want to unhook the spring ??? Because of the servo load ? You might as well unhook the elevator servo too due to the load on it while pulling a loop or snap or simply flying around. Just use a nice strong servo on the throttle. I am using a JR 4131 on my DA 50 and a JR 4721 on my DA 100. No problems at all.
As for the needle adjustment: You will need to set the low end if you change and experiment with props. It's the same as with your 40 size glow engine. No problems or surprises here.
Old 03-16-2004, 07:25 PM
nonstoprc
My Feedback: (90)
nonstoprc's Avatar
With a digital scale, I was able to determine that about 5oz of mass is enough to open thruttle to the full position. In this situation, there should not be high current draw to the thruttle servo.
So it is better to leave the spring as is.
Old 03-17-2004, 08:33 AM
RickP
RickP's Avatar
ORIGINAL: Texas 3D
Because the manufacturer says to that's why - and that's what I did
RickP
Old 03-17-2004, 09:12 AM
nonstoprc
My Feedback: (90)
nonstoprc's Avatar
Well, I believe in data more.
Old 03-17-2004, 10:47 AM
Texas 3D
Texas 3D's Avatar
ORIGINAL: nonstoprc
