Go Back  RCU Forums > Glow Engines, Gas Engines, Fuel & Mfg Support Forums > Gas Engines
will Coleman fuel / white gas and oil 40:1 work?
Old 03-11-2004, 09:17 AM
tony_kilwein
Default will Coleman fuel / white gas and oil 40:1 work?
Has anyone used coleman fuel / white gas and oil in the 3w's or DA engines?
I have seen this work on custom made engines and they run good!!
Is there a problem with using it with the right oil mix?
Tony
Moderator's note: The Title was changed to reflect a fuel - oil ratio of 40:1 (2.5%) instead of being 40% oil which I think was his original intentions? -- Jim
Old 03-11-2004, 10:07 AM
JBrannon
JBrannon's Avatar
Default RE: will Coleman fuel / white gas and oil 40% work?
You would have to know what octane rating it has and see if it matches your engine manufacturers recommendations. If you really want to use "white" gas, I know all Amaco gasoline used to be "white" gas.
Joe
Old 03-11-2004, 11:39 AM
RTK
RTK's Avatar
TONY- One time when I was hunting a friend ran out of gas. So we used coleman fuel. It worked but, pinked liked crazy!
Old 03-11-2004, 11:48 AM
w8ye
w8ye's Avatar
Coleman fuel itself runs great in a gas model engine but people use a fuel - oil ratio of 40:1 and also various other ratios from 32:1 and even 100:1 with some oils....
I never was able to get one to start with 40% oil. It was expensive too. I put bar oil in the wrong tank on a chain saw one time.
The Coleman fuel doesn't ping in the usual engine and it smells better than gasoline.
Enjoy,
Jim
Old 03-11-2004, 01:04 PM
jongurley
My Feedback: (29)
jongurley's Avatar
Why would you want to do this, this sounds strange, would you gain any power or burn cleaner or what, just wondering thx..
Old 03-11-2004, 01:08 PM
GeraldRosebery
My Feedback: (14)
ORIGINAL: jongurley
What most people have told me is that they use Coleman fuel because it does not smell like gasoline. (It's a wife thing.)
Old 03-11-2004, 05:34 PM
RTK
RTK's Avatar
If that is a problem you can purchase different scents that can be added to gas. I do not know who makes them, but everybody that uses them say they are great! Especially the wives. Many Many flavors.
Old 03-11-2004, 06:55 PM
BBW Walt
BBW Walt's Avatar
ORIGINAL: RTK
Hard boiled eggs work for me!![:'(]
Old 03-11-2004, 07:04 PM
RNick
RNick's Avatar
A friend runs coleman fuel in his DA50 with the normal oil mix and it runs great and he doesn't have to breath gas in his van on the way home from flying.
Randy
Old 03-11-2004, 08:28 PM
JBrannon
JBrannon's Avatar
ORIGINAL: r nick
Randy
He is still breathing it, he just doesnt smell it.
Joe
Old 03-11-2004, 08:38 PM
msulka
who knows what is really in there. the only thing for sure is that there is NOT gum in coleman fuel. but as to btu/lb or octane ratings, anyone's guess.
if you smell it, there is a leak. Is this typical of model tanks? I don't have actual models with gas, but I am working on it. I will make my own tanks if they leak. If it is the exhaust, it should smell like the oil used.
I would say Race gas from the specialty petroleum store, LL100 from the airport, or super unleaded from the "pump," in order of preference. the order completely reverses when considered in order of reality (the race gas is probably $5 per gallon).
Old 03-11-2004, 08:45 PM
msulka
Oh yeah:
if the gas leaks, you can have a BAD fire/possible explosion.
but if the coleman fuel leaks, you can have a WAY BAD EXPLOSION FLASH FIREBALL FIRE. The difference is really suprising.
if you light a spilled cup of gasoline, it flashes up and you think "big fire, put it out, what else is going to get lit?"
if you light a spilled cup of stove fuel, it will suprise you how fast and violent the flash can be (it can scatter campfire kindling, even on a cold night). no time to think anything.
And, that volatility is actually a bad thing when it comes to carbeurated fuels--there is a vapor pressure limit for pump gas, otherwise, things "vaporlock"
Old 03-11-2004, 10:23 PM
tkg
FWIW COleman fuel has an octane rating in the 60-70 range. But most model engines are not octane sensitive. They will lose a bit of power and run a little hotter.
Old 03-12-2004, 10:51 AM
ml3456
A big part of the smell is also the additives in motor gas. Not much of a need for addtives in Coleman fule, and avgas as minimal additves in it since it is refined so specifically. Also, avgas has a higher vapor pressure than motor fuel, eliminating some of the nasty smelling parts of gasoline needed to run. Avgas also evaporates much faster (lots of Toluene in it!), so minimal smell.
Mark
Old 03-12-2004, 11:22 AM
branded
My Feedback: (9)
ORIGINAL: tkg
DITTO!
Old 03-12-2004, 12:02 PM
Rodney
Coleman fuel works quite well. I agree with Clarance Lee on the fact the octane ratings on this size engine is meaningless. It will run as well or better on the lower octane mixes. I personally use as much oil as I can without fouling the plugs, usually about 30 to 40%.
Moderator's note: He apparently means a ratio of 30:1 (3.33%) to 40:1 (2.5%) oil. This has caused a problem in this thread so far. Some of you have not picked up on this error while others have become frustrated about this fact. --- Jim
Old 03-12-2004, 12:13 PM
JBrannon
JBrannon's Avatar
ORIGINAL: Rodney
Dont you mean 30 or 40:1. You had better be careful betting your piston and jug on what people say here. Most of this info is second hand. B*M*E requires you to run 87 octane, Z*D*Z requires 92 octane. Running low octane fuel on a hot day or with poor engine cooling could easily burn a hole in your piston.
If you drain all the fuel and plug all the lines to your fuel tank you will have very little gasoline smell. There was another thread here recently about this , some people posted a link where you could buy, at a premium price, oderless fuel that had the required octane ratings. This topic seems to come up once a month.
Joe
Edit: Edited to remove links
Old 03-12-2004, 12:16 PM
JBrannon
JBrannon's Avatar
OK RC Universe Moderator, why do you have to hose my post with a poorly written script to an advertisment?
Joe
Moderator's note: My efforts to edit the thread above and also of this person's efforts to edit the post have failed. He has re-written the post to say essentially the same things in different words in a effort to eliminate the jibberish in the post but it doesn't show up on the screen. I have alerted management about this fact. -- Jim
Moderator's second note:Another moderator happened along and was able to correct the post by splitting up the key advertising words to get rid of the bad programming situation for now.
Old 03-12-2004, 01:51 PM
branded
My Feedback: (9)
ORIGINAL: JBrannon
ORIGINAL: Rodney
Joe
I have been using Coleman fuel exclusively in my ZDZ80, GT80, G38's and my DA50's. I have used Coleman on and off (depends on availability) for the past ten years.
Werks for me!
Old 03-12-2004, 06:45 PM
Geistware
Default RE: will Coleman fuel / white gas and oil 40:1 work?
I tried to get 100LL once and could not get it.
Old 03-12-2004, 09:55 PM
mvigod
Banned
JBrannon - this was my coding error. I have been looking for any possible things I missed. From what I understand when you would type ZDZ or the word BME it would toss extra garbage after the word. My post here will see if that is fixed. I apologize for any oversight in my coding but with very very long days mistakes can happen when humans are coding.
Old 03-12-2004, 10:00 PM
mvigod
Banned
Yes. this was an error which I am looking into now and disabled the keyword program until it is fixed. thank you for bringing this to my attention.
Old 03-12-2004, 11:56 PM
smokingcrater
ok, sounds like coleman fuel works with the possible problem of low octane causing high heat. how about a shot of 104 octane boost? wouldn't take much, they advertise 1 bottle treats 16 gallons of normal gasoline.
Old 03-13-2004, 09:56 AM
JBrannon
JBrannon's Avatar
If you go to an airport to buy avgas, by law they cannot pump it into anything but an airplane labaled 100LL avgas. But if you talk to some of the people or know some pilots you may get them to over look the law.
Joe
ORIGINAL: Geistware
Old 03-13-2004, 11:12 AM
Desertrat
Desertrat's Avatar
A word to the wise: this thread is filled with a lot of significant misinformation. There are also some pearls of wisdom. Rather than go into which is which and start a flame war, I caution each of you to research on the web the following: Race fuel, AVGAS, White Gas, Coleman Fuel, Vapor Pressure, and Octane, specifically when used in 2 cycle applications. The motorcycle guys have been at this a lot longer than us, and have some very good articles out there.
<edit My Opinion removed>
Roger
