sig something extra cg
My Feedback: (24)
MS
I am running at 4" back from the leading edge and still have a good handling plane with a Saito .72. While you're at it consider building a larger rudder (150%-200%) for good knife edge and hover control. They look good and fly well don't they?
quint
quint
My Feedback: (21)
Chevy 13 ; If you'll get rid of that brick you call an engine ( OS70 ) & get a real motor ( Saito 72 ) then you could move your CG back without adding weight.
IL
Somethin' Extra/Saito 72
I agree with Quint, I have the same setup he has - Saito 72 with CG at 4" (I think I could go back anouther qtr inch to half an inch). My SE has no added weight and does the unlimited vertical thing when asked. I am turning a shaved off, re-balanced 14 x 5 Zinger prop and I have to stick my landings 'cause I have about 3/4 of an inch ground clearance! I have seen other SE with about an inch added on the rudder - I haven't done this yet and mine still can do a pretty respectable knife edge. I'm sure it would help with the hover control. I have three 1/4 scale planes and keep coming back to the SE - I love this plane!
My Feedback: (24)
MS
SearchMan, I replaced the tiny stock gear with a fiberglass one from the local hobby shop, opted for slightly larger litefoam wheels and kept the stock wheelpants. The .72 swings a 13 x 6 with good clearance and looks even better on the new SE gear legs. Balance was like yours after the larger rudder added some tail weight. Now it will knife edge the length of our field and hover till you get tired, but it won't climb enough to do a knife edge loop. - Just not enough side area for that.
Swaped the small tank for a 10 oz. one to feed the thirsty .72 so there went the tail weight gains Still the answer to the original question ended up 4" for me.
quint
quint
