Ultra Stick 60
My Feedback: (174)
Ultra Stick 60
Hey Pud, I aggree with you on the best flying airplane, I found another function you can get which you can switch on or off and that is flaps(including the ailerons), this is if your using a Futaba 8U series radio. Just go to the START set up in the glider menu which you are using if your using the Crow set up. I haven't flown yet since I set this up but will let you know how it works.
