rear steer
VA
RE: rear steer
I thought about the usefulness of this. I would have very little to no application for it so I kind of trailed off. There is room on the back for a servo and the linkage could be made from odds and ends shopping on Tower or the like. Use one of those cables that splits up RX servo output to two connectors, which is more popular in planes to tie the front output to the rear also. Thats about where my thoughts stop. If you arent using the 3rd channel for reverse you could make a switch to enable/disable the rear steering with it, just make sure the rear is centered properly before you turn it off (and center the fron before you engage of course).....
TN
RE: rear steer
i know what, get like a weed eater engine, that would have low rpm's and high torque. just you would have to customize everything for it to work.
