How to setup FF8 with a 4CH RX?
Hi,
Have a small handlaunch glider for 3 servos (2 ailerons and 1 elevator). I
would like to use my FF8 with a small 4 channel Robbe RX. Choosing the
AILERON DIFFERANTIAL mode it means I have to use CH1 and 7 on my RX. But is
their a way to disable eg. the throttle stick and to mix CH7 to eg CH3? In
other words: would like to use a 4CH RX to operate the 2 ailerons.
Thanks a lot for your help,
Ragards,
J
Ragards,
J
RE: How to setup FF8 with a 4CH RX?
get a Y lead and plug it into the aileron slot.
if you NEED! flaps plug the other aileron into the throttle and mix it so when you pull back you get flaps to slow you down.
as for differential just have the servo arm at a slight angle, this will sort out that little tiny problem.
