possible to cover ABS and epoxy parts??
My Feedback: (18)
Here's an article on covering fiberglass with monokote
http://www.modelairplanenews.com/how_to/monokote.asp
If you are using Oracover (Ultracote with a different name), wouldn't it be easier to get the matching paint and paint them ? Ultracote now has matching paint in spray cans that work 1,000% better than the Lusterkote paints.
ultracote still doesn't make the paint in metalic colors[:@]
Im having the problem myself. I am building a GP Extra 300 40 size and I wanted to use some nice met. but no paint to match the cowl or pants [&o]
I used Oratex to cover my ABS canopy. And it works great aslong as the temp is not to high.
Some gasbubbles are easy to remove by making a small cut in the bubble.
