Throttle Horn and linkage hookup for ZDZ motors
My Feedback: (28)
IA
I need to know where you get or make a throttle horn for the rear mounted walbro carbs on ZDZ motors or such rear mounted carbs> The stock horn on the carbs are not set up right i understand for the set up . Thanks Bruce
My Feedback: (7)
AK
RE: Throttle Horn and linkage hookup for ZDZ motors
The ZDZ motors come with a ball link end that goes over the throttle shaft. I have also used a 1/2 A nose gear steering arm and a dubro EZ link. I used a dremel to grind the end of the shaft so you can pull off the existing throttle linkage plate then slide the new on and use the set screw to tighten it.
