Question about mounting tires
Old 05-10-2004, 01:47 PM
Benbot
Default Question about mounting tires
Sorry for such an elementary question, but I'm new to R/C cars and I want to make sure I do this correctly. I know I need to use thin CA to bond the tires to the wheel rims, but do I need to glue the foam insert to the inside of the tires? And if so, what kind of glue should I use? Should the tires and the wheels be washed beforehand?
Thanks again for your help.
Old 05-10-2004, 02:00 PM
RCFreakInFL
Banned
Default RE: Question about mounting tires
The foam insert does not need to be glued. Just the tire to the inside rim. I usually wash the tires with a soap solution before I apply the CA, just make sure they are dry before applying.
Old 05-10-2004, 02:58 PM
Vanquish24
Yup yup just like you would with your bodies before applying paint. It just holds better.
Old 05-10-2004, 03:55 PM
dryvr
dryvr's Avatar
If you don't have much experience glueing tires, I would use a thick tire glue. Using this type of glue will allow you time to set your bead correctly and fix any mistakes you might make. Thin glue dries very quickly and if you don't know what you're doing, things will get out of hand. I use team losi tire glue, I use the thick for glueing tires to rims and thin for spot glueing. Sometimes after you glue tires and use them you'll find little sections where the tire has pulled away from the rim, the thin glue fixes this quickly. I use denatured alcohol before I glue my tires, it removes the shipping protectant in the tires and allows for a good bond. Hope this helps.
Old 05-10-2004, 04:23 PM
nitrofreak74
couldnt have said it better!!!
Old 05-10-2004, 06:51 PM
switchlead
switchlead's Avatar
ORIGINAL: Benbot
The only stupid question is the unasked question.
Old 05-10-2004, 10:26 PM
newbie003
newbie003's Avatar
will the venom "hands free tire gluer" work on 1/10 scale on road car wheels?
Old 05-12-2004, 11:28 AM
Benbot
Ok, I'm having another small problem. How exactly do you mount tires on the wheels anyway? It takes a considerable amount of effort to pry them on, and I'm concerned that the tire's foam is getting bunched up underneath. How do you guys deal with this problem?
Old 05-12-2004, 12:57 PM
vtl1180ny
What kind of tires are you trying to mount on what rims??? Want to get real nuts??? I Balance all the wheels after mounting... Hahaha...
Old 05-12-2004, 01:54 PM
Benbot
They are just your standard 26mm HPI wheels, with touring tires and foam inserts. I'm not so crazy that I need to balance them, I just want to make they're not lumpy and wobbly.
