Hummingbird CP pitch setup
OH
Hi all, I just purchased the HB collective pitch and for the most part have it set up. I have not had it off the ground more than an inch for a second or so but have done alot of scooting around trying to get it trimmed out a bit and get use to it. I have been out of RC for about two years but have only flown fixed wing so this is alot different although I understand alot of what is going on. Anyhow the kit came with a pitch gauge but the manual has no explanation on exactly hot to use it. I thought I would try to get some info here before sending an e-mail to Century. I would imagine you sight the number ticks up with the flybar but this just dont seem very exact at all. Plus you would have to get the flybar perfectly level for it to work as well.
ON, CANADA
Hi
U have to put the gauge close to the flybar to able to see the degree.
this web site will help u to setup the pitch and throlle.
http://www.helifever.com/modules.php...howpage&pid=14
jerry
jerry
ORIGINAL: Jerrykl720
Hi
jerry
Hi
jerry
I'm also trying to get my new Hummingbird CP pitch set up correctly. The only thing mentioned is the 25mm from ball link center to the 'z' bend on the servo arms. It looks like at full throttle setting the swashplate is right at the maximum.
However, I can't seem to get the thing off the ground. I'm wondering if it's either a pitch/throttle mixing issue in the radio (right now I just have both the pitch and throttle curves set to completely linear), or if I need to increase the pitch on the blades via the top ball links on the rotor head (the same ones you use to adjust the blade tracking).
Any suggestions would be great. I'm finally getting comfortable with my other FP in the garage and I'm anxious to get the CP in the air as well.
-Ken
AL
If you set up your Hummingbird CP according to the manual it is probably set up wrong. The manual has some mistakes in it. I had to take mine back to the LHS and have them check it out. Here is a thread about the manual problems.
[link=http://www.rcuniverse.com/forum/m_1901507/anchors_1901507/mpage_1/key_/anchor/tm.htm#1901507]Set up[/link]
