fuji 32
My Feedback: (21)
fuji 32
I have a fuji 32 that was damaged in a crash. The flywheel has approx 3/32 inch runout now. Engine shaft is straight so the flywheel must be the problem. I have checked the flywheel and it appears to be straight also so I am thinking the problem is with the pressed in taper section that has the keyway in it. Any ideas on how to fix this?
Larry
Larry
