Servo help Aid
Servo help Aid
Look at this idea. Remember how much fun is to install the brass eyelets into the servo grommets. And have you ever had to take a brass eyelet out of the grommet after it has been there for a while. Like when you damage a servo case in a crash and need to install a new case.
Slide the eyelet onto the small end of this device and insert the eyelets into the bottom of the grommet very easy on the thumbs.
Need to remove the eyelet. Just push on the eyelet from the top and this device will push it out.
And it you don't have the servo drill template install the servo into the servo tray and push through the evelet with the pointed end of the device and now you have a punch mark for the drill to follow.
Lee
[email protected]
Lee
[email protected]
Servo Help Aid
Phillco
Glad to be of assistance. The larger machined diameter is .150" and the smaller diameter is .095" for Fautabia and .120" for JR.
Sharpening the small end and make a punch for drilling servo screw hole.
Happy Machining.
Lee
Happy Machining.
Lee
