smartech winner sport engine connecting rod
RE: smartech winner sport engine connecting rod
it isnt for me......i recieved an email asking about an engine conecting rod and have conducted searches and came up with nothing so i decided to turn to good old rc univrse
Hopefully the following links will help you.
http://www.goldstarstockists.com/tam...ech-winner.htm
http://www.ktmodels.co.uk/html/smart...r_3_parts.html
http://www.qd-race.com/parts_smartech1.html
thanks roy but none of those links helped but thanks anyways.... i am not to sure if it is actually called the connecting rod but read this it may help............................If you take off the header and right beneath the piston, there is a rod that connects the piston to the crank shaft, anyone know where i can get that part?
if its the rod set from the servo to the throttle you will need: 11344
if its th universal joint shaft
78mm:11432
65mm:11433
73mm11434
just search for these on gold star stockists or kt models on the links above.
I hope this answers your question
78mm:11432
65mm:11433
73mm11434
My Feedback: (14)
There is a store called Excelhobby they have parts for all smartech products. Go to www.excelhobby.com
I hope this will be usefull.
