Transmitter doesnt work on FMS
PA
Hi,
i just bought an esky honeybee and i want to practice on FMS before i break it i downloaded FMS but my controller wont work on it
(im running on windows XP) is there something i can do or a program i can download to get it to work and please explain why it doesnt work.
John
John
FL,
RE: Transmitter doesnt work on FMS
If you're using the parallel port for the hookup w/FMS, that doesn't work in XP or 2000. The parallel works with 95/98/ME only. The serial connection works with 2000 and XP.
What type of controller and buddy cable do you have ?
You can try downloading ppjoy and set it up as a standard joystick. I am using this with XP and the ZenShua controller and buddy cable...
You need to run ppjoyCOM to set up a ZebShua virtual port then add the virtual port with the ppjoy utility
This is a link I found
http://www.geocities.com/deonvdw/Docs/PPJoyMain.htm
Wow,
just noticed that you can use the Zhen Hua controller with the power OFF !!!
This is great. I am installing all my older games to use it as a joystick. Its great for the Need for speed types, revolt, motoracer, however it is useless when you need to shoot since it does not have a button.
Anyone know how to get a button working with this controller ?
