futaba PCM crystal cross talk?
NY
check this out;
I had a TX87 Crystal in the radio and by accident a rx74 Crystal in the receiver.
problem is IT WAS WORKING!!!??? how can this be?
It didn't work smooth but it WAS moving the throttle and steering.
is there some cross talk between crystals? I was In PCM mode, with digital futaba servos...
I thought in PCM mode the reciever needed a "code" before it would even listen to a signal, I'm really confused here..... HELP!!!
here are the story line,
went to track with 87 in everything. changed to 74 cause a visitor had 87 and nothing else.
went home and put 87 back in radio but forgot to put 87 back in car.
futaba 3pk---113ip -9350 and 9450 in a mbx4xr
