dual servo aileron and dual servo stab help
My Feedback: (125)
OR
So I'm building my first large scale palne. I have two servo's per wing and the stab (elevator) has a server for each half. And a pull-pull for the rudder.
I've read in some forums that each servo on the aileron and stab can be connected to the receiver. I've also read that you can use Y cables. I have a 9CAP transmitter.
What is the best way to go about and connect all of the servo's?
Thanks!
Thanks!
My Feedback: (21)
RE: dual servo aileron and dual servo stab help
Has a lot to do with what servos your using. Are you using Digitals or Analog, and if so, what brand and servo model? Reason being is because if you run saw Hitec, you can program them so they all match exactly, saving you a matching device, same with analog servos. If you run JR, you can use a match box, which basically act's like a wye connector and matches the aileron servos up and connects into one serial port in the rx.
Generally, you want to avoid (if possible) as many y connectors as you can.
My Feedback: (21)
Ah alright, well for the elevator on my plane using Hitec 5645s I used a program mix in my Futaba 9cap where I LINKED the two servos together, so when I trimmed the servo using the normal digital trim it would trim both, if you dont do this, you will end up trimming one half an elevator and getting a plane that flys very odd[8D]. I plugged them into 2 seperate channels, 2 and 8 I believe it was.
For the Ailerons, its probably easiest if you use a wye and connect the right aileron to channel 1 and then one more wye for the left aileron in channel 5 or whatever it was.
If you have a power buss or distribution system it can be done differently.
I always use separate channels for each servo. I don't have the hitec programmer, and it is very nice to use the sub-trims and endpoints for each servo to get the center and travel of each control surface to match. (You definately want to get it as close as possible with mechanical adjustments to the linkages first) There are standard mixes ("Flaperon" for ailerons, and "Ailevator" for elevators)" in the 9C radio so you don't need to use mixes. You can turn off the "flap" action of the ailerons and the "ailevator" action of the elevators so that you don't bump a knob and have something wierd happen.. The trim settings will work on both servos, while the sub-trim will work on individual servos. The manual or the example will tell you which channels to plug in to, but for ailerons I believe it is 1 and 6, and for elevators it is 2 and 8. If you have only a 7 channel receiver, you will have to use a mix for the elevator servos.
FC
FC
