kangaroo mark 2
kangaroo mark 2
the instructions are not very clear .how do i fix the wings on any pictures please i got the tube .in my reaper you bolt through the tube and secure in the air frame .thanks all
My Feedback: (7)
RE: kangaroo mark 2
The wing is suposed to be bolted thru the root rib thru the vertical and into the side of the fuse into a blind nut. I hate the way the directions say to do it and am trying to find a cleaner way. To do it the way the book says you have to cut a ugly hole in the wing to fit the bolt thru to install the wing and tighten down.[:'(] I will try to get you a better discription and picture tomorrow[8D]
RE: kangaroo mark 2
Hi DJ
As Todd's link says, you can do the reverse to the instruction. Put the blind nut in the wing and then fasten the wing bolt through the wheel well. I have done this to my Roo and it works well. You will need an Allan Cap type screwdriver to access the bolts easily but it is definitely worth the inconvenience.
Enjoy the Roo, they are great!
Regards
Zane
Regards
Zane
