carb. problem
carb. problem
im having a problem with my carb. the part that slide< forgot what its called, is sticking very badly while im running. anyone else having this problem. i have to un-stick it with my hand and it is hard. it is a savage ss by the way. HELP!!!!
RE: carb. problem
i tried lubing it. it helped a little. it only sticks when i hit the brakes. i just started brake in today and this is putting me down... anyone ever have this problem. maybe the carb. just wasnt built up right...
RE: carb. problem
Sounds like the low end needle is turned in to far to me. try turning it counter clock wise about 1/4 of a turn and try it again. Might need some more, but keep trying that.
RE: carb. problem
hmm ya. ill check. but i wouldnt think it is that but it could be. the thing is that this was its first day running. i broke it in and it didnt start till i started tuning. so maybe it is the needle. but could it alos be that it is just new and needs to work itself into like a "groove" of parts being used to run together and stuff. that was my other thought. thanks for the help and all other help is great. thanls alot guys1!
RE: carb. problem
YESYESYESYESYESYESYESYESYESYESYESYESYESYESYESYESYE SYESYESYESYESYESYESYESYESYESYESYESYESYESYESYESYESY ESYESYESYESYESYESYESYESYESYESYESYESYESYESYESYESYES YESYESYESYESYESYESYESYESYESYESYESYESYESYESYESYESYE SYESYESYESYESYESYESYESYESYESYESYESYESYESYESYESYESY ESYESYESYESYESYESYESYESYESYESYESYESYESYESYESYESYES YESYESYESYESYESYESYESYESYESYESYESYESYESYESYESYESYE SYESYESYESYESYESYESYESYESYESYESYESYESYESYESYESYESY ESYESYESYESYESYESYESYESYESYESYESYESYESYESYESYESYES YESYESYESYESYESYESYESYESYESYESYESYESYESYESYESYESYE SYESYESYESYESYES
srry about the spemm but that was it. it was too far in. i read the engine manual and it says it should be only a half turn max from where it is in break-in so i over turned it and it started sticking. its fixed now and i have my stuff rdy. it should all be good for tomorrow!!!
