Brison 3.2 shaking bad !!!
Old 07-06-2004, 06:59 AM
TailTouch
My Feedback: (54)
TailTouch's Avatar
Default Brison 3.2 shaking bad !!!
Hi All.
I have a Brison 3.2 with about 2.5 gallons thru it. Lately it's started shaking quite a bit.
The Ailerons & elevator halves shake real bad at idle and even at half throttle. Plane is a 16 lbs Lanier CAP-232.
It's so bad that, when the plane is in the air, it seems like a radio glitch (It's not radio glitch, I have range checked many times with the engine running).
And yes, I have a balanced prop and have even tried different props but the airframe still shakes crazy...
Any ideas or suggestions ?
Thanks.
Old 07-06-2004, 07:24 AM
wingburner
My Feedback: (17)
wingburner's Avatar
Default RE: Brison 3.2 shaking bad !!!
You may have done this already but they will shake bad if the carb. is not properly set.Perhaps it's breaking in and needs to be leaned out a little.
Jack
Old 07-06-2004, 08:52 AM
Sailor
Also, check your firewall. I had a BME 50 do that to me, and I found that my firewall was loose.
Old 07-06-2004, 12:42 PM
ml3456
Had the same problem. I had to lean it quite a bit and it ran much smoother. After it breaks in, lean it out until you hear it sag when increasing the throttle, then open the low needle slightly. Check the high end to make sure it is not too lean,
Mark
Old 07-06-2004, 05:46 PM
ptgarcia
My Feedback: (36)
ptgarcia's Avatar
Check the obvious, but usually overlooked...firewall and engine mounting bolts. Good luck!
Old 07-06-2004, 07:21 PM
Geistware
Lean out the idle setting. It will shake less.
Make sure that the mid range is good
Old 07-08-2004, 03:16 PM
TailTouch
My Feedback: (54)
TailTouch's Avatar
Firewall and engine mounting are solid...
I will check if the engine is running rich.
Thanks for all your help.
