Fuel line size for 80-100cc engine
DC
RE: Fuel line size for 80-100cc engine
I run everything on my test stand with 1/16 inside diameter molded neoprene..150cc engines included....There is no benefit to running fuel line with a larger diameter than the hole in the carb controlled by the rubber tipped inlet needle..It's smaller than 1/16....A garden hose won't put any more fuel through the hole....[8D]
