Help problems with Airtronics
I turn on my radio my car and everything responds fine. I then start up my car and it just keeps idling higher and higher. I pull the throttle and it moves the servo, but the car doesn't move the brakes also work fine. the only problem is that I pull the throttle and the car doesn't move. CAN ANYONE HELP! What could be wrong?
Ryan
Ryan
RE: Help problems with Airtronics
I'd check the linkage as from what you describe the servo is moving.As far as the idle keep getting higher and higher you may have a air leak or idle set wrong and it's gets higher as the engine warms up. Cold engine requires a richer setting than a warm engine.
