spur gear
NF, CANADA
RE: spur gear
make sure your engine is alligned properly with the gear beacuse i had a similar problem. it stripped the top part of the spur gear. if you re align in and make sure it has a tight fit it still may be usable. mine was.
RE: spur gear
ORIGINAL: pakfan
help jus went through a spur gear in 20 mins. lhs is 35 mins away.will metal solve this.!!!
help
thx
help
thx
I hope this helps.
KS
RE: spur gear
i stripped one spur and automatically went to a metal gear. (stupid move[:@]) its better just to keep buying cheap plastic ones to have around. ALWAYS CHECK YOUR MESH!!! and be sure your spur is tightened down all the way and 1/2 turn out.
