Help! Astro 020 Heli brushless motor work on a 20-30 0z Plane slow stick?
DC
Will I be able to use astro 020 motor corona brushless meant for a helicopter transfer to a 20 to 30 0z GWS slow stick Plane? I wanted the extra power for AP (aerial Photograpghy). I have a 11volt thunder power 2100 mah with 35 amp castle creation I want to mate this with. will it work?
Direct drive Astro 020's are used as a hop up motor for 20+ oz. Zagi's Makes them go really fast. If you gear it, put a large diameter prop on and put it on a slow flyer, it would work. The trick is to get the right gearing, the right sized prop, the right current draw, the right pitch speed for the planes requirements...
If noone here has better information, then go to [link=http://www.rcuniverse.com/forum/default.asp?fh=1&forumid=227]the electric plane forum[/link] on this same board. Lots of places to learn more, and ask questions.
