Which engine is better?
NE
I currently have a Megatech NEO .16 st engine on my MT. Six tanks thru it, but I also have a HPI 15fe engine, with about 1/2 gallon thru it. Now my question is which is better? I'm really looking for power instead of speed. Thanks.
NE
RE: Which engine is better?
Okay, here are the specs for the two engines
Megatech NEO .16 ST
Max RPM 31,500
B.H.P. .74@29,500 RPM
Bore 15.1 mm
Stroke 13.77 mm
Displacement 15.99cc
HPI 15FE
Displacement 2.48cc
Bore 15.3 mm
Stroke 13.5mm
PS/RPM .56hp/29,00 RPM
RPM Range 3,000-32,000
So can someone tell me which ones better? It looks like the NEO is better, but it is such a pain to tune, any suggestions would be helpful
Megatech NEO .16 ST
Max RPM 31,500
Bore 15.1 mm
Stroke 13.77 mm
HPI 15FE
Displacement 2.48cc
Bore 15.3 mm
Stroke 13.5mm
I dont know about the Neo but the .15FE is just the average run off the mill decent engine..
Tuning wise.. its easy as hell to tune..
It sounds like the neo would perform better.. difference of .18 is kinda significant.. thats a 30% difference.
I guess its your call man.
good luck
ram
good luck
ram
