DA-100 Prop tighten confusion
Old 07-31-2004, 06:26 PM
Gotta_Fly
Default DA-100 Prop tighten confusion
Hey Fellows
I have a new DA-100 and a new 27x10 NX prop,And tommorrow I'm doing its maiden flight BUT being new to the giant scale world when I put the prop on and tighten it down it seems like it want say tighten, another words if I tighten one screw in and go all the way around when I get back to the first screw it seems like I have to keep screwing it in, well after about 4 or 5 times going around you would think its tight but for some strange reason I can take one screw and just barley turn it the other way to unloosen it and it just seems like if I make a 1/4 of a turn the screw will come completely lose, Now I'm I missing something here, I'm I supposed to do something else when putting my props on like use some lock tight, because right now I'm almost sure the prop will come off the way its going now, and I really don't feel like losing a $140 dollar Tru-Turn and the prop, So I'm I missing something????
Old 07-31-2004, 07:11 PM
RCAIR-BAM
Default RE: DA-100 Prop tighten confusion
Gotta fly:
Are you tightening the bolts in a criss cross pattern or right around the clock?
KG
NO lock tite.
Old 07-31-2004, 07:18 PM
Gotta_Fly
I'm doing it in a circle, But I was just told that I was doing it wrong it needs to be in a crossed pattern, If I go back and un-losen it and start over it will work this time right??? another words i couldnt have mess anything up could I ??????
Randy
Old 07-31-2004, 07:24 PM
RCAIR-BAM
Gotta fly:
Should be fine. set the bolt pattern so you have a bolt at 12 and 6 o'clock. start at 12 then 6, 2, 8, 4, 10 on the clock respectivley. then reverse starting at 6. I go thru 3 times for a final tightning start by just snugging the bolts.
Kevin
Old 07-31-2004, 07:33 PM
RCAIR-BAM
Randy:
Also check after the first flight. the wood on the prop will crush a little> i always wick some thin Ca through the bolt holes too.
Kevin
Old 07-31-2004, 09:37 PM
CDignition
My Feedback: (9)
Just for chuckles... the term "un-loosen" actually means tighten,lol..I think you mean "loosen"..
Old 07-31-2004, 09:57 PM
rmh
rmh's Avatar
If all bolt holes are exactly centered (drill props from rear surface if possible) then use drill pressand slightly increase hole diameter
If you do not do this ----the wood crushes against the bolts !
Now All of the bolts should easily drop thru the front washer - thru the prop and thru the spinner backplate - this allows you to spin all of them into the hub --THEN tighten.
Old 07-31-2004, 10:33 PM
Gotta_Fly
Thanks so much guys, Hey CGigniton what was I thinking Un-Losen lol, Hey this is Randy from Nashville, did you ever have that picture of your CG stand. Thanks again
Randy
Old 08-01-2004, 02:10 AM
JohnVH
My Feedback: (38)
JohnVH's Avatar
Randy, make sure to check the prop bolts every so many flights too.... I had 4 of mine break on my 100 just after landing from a bunch of hovering right in front of me[X(]
Old 08-01-2004, 01:58 PM
one budlight
I had one break on first fly,replaced it and good from then on
Old 08-01-2004, 06:05 PM
CDignition
My Feedback: (9)
Hi Randy...Just funnin ya..
