Radio interference on a 1/4 scale AT6
IN
I have an At6 with a gas motor running a 6.0 volt rx battery. I get radio clitchs anytime the motor is running and gets worse with higher rpm. I have tried several batteries and radios. I remember reading about this before but can not seem to find it. Thanks for any help you may have
My Feedback: (61)
RE: Radio interference on a 1/4 scale AT6
How about al ittle more info...
1> what kind of engine - magneto (i.e. Zenoah) or ignition (i.e. DA, 3W) - are you sure you have a resistor plug?
2> what type and brand receiver - (PCM / PPM ) and (JR/FUT/etc)
3> are you using a regulator on your 6V battery ?
4> what type and brand of switches are you using?
5> what brand of radio gear (TX) ?
answer these and I probably can help you fix it...
DP
DP
