Alright I made 4 wheel steering
Alright, I made 4 wheel steering for my savage. Two questions, Does someone make a a servo wire extender or something so the servo wire can reach the reciever? And does someone make a servo mixer or something so i can make the front and rear steer at the same time? Any help would be appreciated. Thanks.
PA
RE: Alright I made 4 wheel steering
Tower hobbies sells the servo wire extensions. You should be able to swap the wires around so they steer in opposite directions if thats what you need. OR you can do something even easier and just swap the servo arm around 180 degrees so that the servos turn the same way but the wheels turn in the direction you want....of course thats only if its possible to do with your setup. (i dont own a savage so i dont know how its set up) At least thats the way we used to do it on the clods.
Of course that also depends on whether the setup you are using is a dual servo setup.
Mike
Mike
