Drilling a cap screw head
My Feedback: (10)
You don't have to do anything, really... but if you're talking about the
socket head screws with the ridges on the outside, I used to grind the
ridges flat with my dremel, just to make it easier on my drill bits.
(Just grind the ridges flush with the head, at the place where you want the hole)
The actual drilling should be done in a drill press if possible, and using carbide bits.
You can do it without either, but you may end up breaking bits.
At any rate, if the bolts are grade 8, you'll probably waste a bit or two anyway.
