prop for saito 1.8 on Hangar 9 edge 540 1/4 scale
I have a Hangar 9 Edge 540 with a Saito 1.80 on it and I'm using a 16-6 prop now and when coming in for landings the plane doesn't want to slow down. Is this the correct prop? Why won't it slow down?
RE: prop for saito 1.8 on Hangar 9 edge 540 1/4 scale
I ran a Pro Zinger 18x6 and an APC 16x8. I had better vertical and a higher top speed with the APC. I had more contol in a hover and torque roll and better downline and level braking with the 18x6. If I could only pick one prop I would pick the 18x6. Dont get a regular Zinger or a plastic master airscrew. Both are only good for paint mixing sticks. But pretty much any other prop will be good.
My Feedback: (172)
On my H9 Edge I'm using a 16x8 APC with the Saito180. Make sure you have a good low idle. Set up your approach, let it settle,when wheels touch, bring it to the low idle as you slowly feed in up to bring the tail down.
Rick
Rick
