s-25 carb, 5 turn from out and 270!!!!!!!!!
ON, CANADA
my hpi savage it getting on my nerves now. teh carb is now set to about 5 1/4 from out and the temp is at least 258 now. ***? teh carb is messed. i have the motor saver air filter on and the hpi ribbed pipe. the body is cut alot to get air over the engien and teh air filter is not undre the roll bar, i had to put it to the side of teh air filter and cut teh body to get more air over the engine, should i get a new carb?
RE: s-25 carb, 5 turn from out and 270!!!!!!!!!
ORIGINAL: Spudnik
My Feedback: (-1)
you have to set your lsn and high speed needle so they will balance out. Set lsn to about 3.5 and hsn to about 4.0. and set the mid range to equal the lsn. That should lower your temps. But really, your temps are kind of good.
there are a lot of factors that can effect temp
gas
glow plugs
weather
the tank half way leaning problem
airflow
wheel and tire size( depending an engine)
gas
glow plugs
weather
airflow
ON, CANADA
i don't know what plug to use, i am using a megatech q series chis whatever his name is plug. i know it is wrong because i am running that plug in my mt2 but is all they have i will put it back to 4 and then see thanks for the help
