Twin & Multi Engine RC Aircraft Discuss the ins & outs of building & flying multi engine rc aircraft here.
C-130
Old 10-04-2004, 10:40 AM
Beplo
Beplo's Avatar
Default C-130
my c-130 in scale 1:10, 158"
Old 10-04-2004, 11:15 AM
Edwin
Default RE: C-130
What engines will you be using? And how about projected weight?
Edwin
Old 10-04-2004, 11:39 AM
Beplo
Beplo's Avatar
Default RE: C-130
Hi Edwin
I will use 4 O.S. 91 FX
The approximate weight will be in 46 lb. / 21 kg.
I want to transport 15lb. / 7 kg. of luggage
Old 10-04-2004, 12:34 PM
Edwin
Default RE: C-130
Some friends and I have been kickin around a C-130 project to use at airshows. Drop a bunch of paratroopers, some cargo, do a low drag chute cargo drop on the runway with hummer on it and have it drive away. Also looking at doing RATO takeoff like fat albert demonstrates. We are looking at using 4 ryobi gas coversions with about the same carrying capacity as what you're looking at. Thats why I was curious about your engine size. We are just at the talking about it stage and havent even decided if we want to actually go thru with it yet.
Nice looking fuse.
Edwin
Old 10-04-2004, 01:16 PM
rdavit
Default RE: C-130
Edwin
Thought of doing same with RATO (D rocket motors). Going with Slurry tank for air drop (1 Gallon).....still flight testing. Would like to see thoughts on RATO.
Bob
ID:	179444   Click image for larger version
Old 10-04-2004, 01:36 PM
Beplo
Beplo's Avatar
Default RE: C-130
Edwin,
Is the idea of my project
In November I am going to fly it for the first time, and there we will know how it flies with those engines...
I know of a similar model with 55 lb. /25 kg of weight and 4 O.S. 60. The model flies, but it only flies. Does not reach to take extra weight.
Enrique
Old 10-04-2004, 03:48 PM
rdavit
Default RE: C-130
Hello Beplo
I'm using Saito 1.20's.....PLENTY of power at 60#'s over all weight, 133" (52#'s static thrust)
Bob
Old 10-04-2004, 07:42 PM
jmupilot
jmupilot's Avatar
Default RE: C-130
A friend of mine and I used 3 C size (rocket) jatos to help lift a piggy backed Space shuttle. He fired them remotely via the retract switchafter the engine throttle was full and the aircraft was on TO roll . The rocket motors were a booster and normal engines. The carring plane was a 40 sized Telemaster that just was a smidge underpowered with the shuttle on it. The rockets sure put the kick in it's butt though. The carrier pilot was rryman who flys a C-130 model now, and posts here in the twin section a lot. He has a few threads under the other C130 posts. It was a hoot to fly the shuttle back as it a was just like the real one, afast glide back to the runway. We havae videos of it and at some points its really hard to tell if its a model shuttle of the real thing.
Pete
Old 10-04-2004, 07:54 PM
khodges
Default RE: C-130
I love Herky Birds and these plans sound great! I was an Air Force Flight Nurse and trained on those and C-141B's. The cargo drop you're talking about is called LAPES (lap-ess) and means Low Altitude Parachute Extraction System. That would really be something to demo at a fly-in! A little known similar system was also designed for the C-141, but it was for air-launching a Minuteman ICBM; the missile was loaded so that when the rear ramp was lowered and the extraction chute was deployed, it would drag the missile out butt-first and as it dropped, with the drogue holding the nose up, the rocket motor would fire. The system was canned when treaties were signed probibiting mobile launchers. Would anyone care to tackle modeling that?!
Another C-130 to model would be the AC-130 Gunship (Spectre) Twin 20mm Gatling guns, a 70mm Bofors twin barrel gun and a 105mm Howitzer, all firing out the left side of the plane. That would be sure to keep the spectators' heads down!
Old 10-04-2004, 07:58 PM
jmupilot
jmupilot's Avatar
Default RE: C-130
Look at the pther threads for the C-130's rryman has one modeled after the Spectra. Its a really beautful model. in the air and on the ground.
Pete
Old 10-04-2004, 08:09 PM
fossil
My Feedback: (25)
Default RE: C-130
Beplo did you scratch build that fuse are is it an available Kit/ARF? If so who has it? I have the quality fiberglass version but would have a larger one. Thanks
fossil
Old 10-04-2004, 08:42 PM
Beplo
Beplo's Avatar
Default RE: C-130
Hello Fossil!
It is a mold of homemade manufacture. it is not a kit. I bought the plane of palmer and I modified it on scale 1:10 (previous authorization of Palmer) Then I made reinforcements of structure according to the size. First I did a molde of the fuselage with foam, Then it was covered of fiber glass, and finally the mold of foam was removed and now the interior is empty.
Best Regards
Enrique
Old 10-04-2004, 09:35 PM
fossil
My Feedback: (25)
Default RE: C-130
That is an awesome job.
fossil
Old 10-04-2004, 09:48 PM
Beplo
Beplo's Avatar
Default RE: C-130
Thank Fossil !!!
Enrique
Old 10-04-2004, 10:49 PM
Ptarmigan
Ptarmigan's Avatar
Default RE: C-130
Nice airplane! You should make it look like the Hurricane Hunter WC-130. [8D]
Old 10-05-2004, 04:41 AM
Beplo
Beplo's Avatar
Default RE: C-130
Hello Bob.
Thanks for the information. I thought to buy Saito 1,20, but I decided to buy the O.S. 91 fx.
Enrique
Old 10-05-2004, 07:29 AM
Edwin
Default RE: C-130
Just figured I'd use a servo to light the rocket motors.
We thought a hummer with a .50 cal on it would be neat. Have a soldier and the gun pop up, use the land transmitter to unlock the clamps and have the hummer drive off doing the rata-tat-tat. Would have to clear the runway pretty quick though.
Edwin
Old 10-05-2004, 01:17 PM
SunShyne
My Feedback: (68)
SunShyne's Avatar
Default RE: C-130
nice looking Herc! Did you make the plane from scratch?
matt
Old 10-05-2004, 01:53 PM
Beplo
Beplo's Avatar
Default RE: C-130
Thanks Ptarmigan
I wished to make a HC-130H of Coast Guard (USCG), but later I decided to make a C-130H of the Argentina Air Force (FAA).
Enrique
Old 10-05-2004, 02:23 PM
Beplo
Beplo's Avatar
Default RE: C-130
Thanks Matt
Yes, I bought the plane of Palmer and I modified it on scale 1:10 (previous authorization of Palmer). Then I made reinforcements of structure according to the size.
I used a 1/48 scale model, besides I visited the Argentina Air Force, to join information.
Enrique
Old 10-05-2004, 04:00 PM
Beplo
Beplo's Avatar
Default RE: C-130
has anybody thrown several paratroopers, or packages from a Hercules?
Enrique
Old 10-05-2004, 05:02 PM
Hegasis
Default RE: C-130
How do you get a rocket motor to fire by remote control?
Old 10-05-2004, 06:14 PM
rdavit
Default RE: C-130
Hummer coming off during "hot landing".....guns ablazing....that would be VERY cool!! (Have an R/C MD 500 provide air support?? Create quite a show).
I thought about setting up with fire jumpers coming out the back of mine (rear door is powered by a pnematic cylinder), but still in process of learning how to fly this monster (4 flights.....83 oz wing loading.....take off and landings a real struggle).
Great to be in good company in here!!
Having a blast.
And Beplo, awesome job on the scratch built fuse.
Bob
p.s. Hegasis....use solar igniters activated by a servo to light rocket motors.
Old 10-05-2004, 09:52 PM
khodges
Default RE: C-130
One thing to consider regarding sliding something out the back of your -130 model is massive rearward c/g shift during the time it takes to offload the Humvee. When you consider the weight of a full-scale 130 and fullscale Humvee, the ratio is much greater than it would be on a model, and therefore would be much more critical on the model. It would probably initiate an uncommanded pitch-up on the aircraft, and since you are at low altitude and probably a reduced airspeed, would possibly spell S-T-A-L-L, unless you have a big surplus of power and a lot of tail surface authority. The faster the off-load the better.
Old 10-05-2004, 10:10 PM
Beplo
Beplo's Avatar
Default RE: C-130
Khodges
I am agree with you about details, in the club we were speaking of that subject, but the result will not be known until the day of the test.
Enrique
