Hydeout CG location
My Feedback: (17)
RE: Hydeout CG location
Hello Chip,
I got a new Funtana S90..Says the CG should be about 7 1/8.. I just want to know is that with the Fuel tank empty or full or half full ? I have never checked my CG with anything in the tank..I was told to do that..Also I am using a YS 110 on it and I have it in the center of my plane not up front like alot of engines..Will this effect me..Thanks for your help with any info you may have..Brandon in FL.
My Feedback: (8)
Brandon,
With your tank on the C.G. it doesn't matter if your full or empty, it won't change your balance. If the tank is in the nose though I would always check balance with it empty.
Chip
Chip
ORIGINAL: stillbrandon
Hello Chip,
Hello Chip,
