Tiger 60 Cowl ?
WA
Tiger 60 Cowl ?
Has anyone seen any good looking cowls on
the front of a Tiger 60. I have a Saito .91 in it.
I flew it for the first time this weekend. It was
a Blast !
a Blast !
OR
RE: Tiger 60 Cowl ?
I don't know of any commercially available cowls for the Tiger 60, but here's a few photos of a homemade cowl I fabricated for my own T60. The cowl itself began life as a large size Scope mouthwash jug...
http://www.jr45.com/qd/t60/DSCF0006-w.jpg
http://www.jr45.com/qd/t60/DSCF0009-w.jpg
http://www.jr45.com/qd/t60/DSCF0011-w.jpg
http://www.jr45.com/qd/t60/DSCF0012-w.jpg
http://www.jr45.com/qd/t60/DSCF0013-w.jpg
First, I side-mounted the engine (which incidentally gave smoother overall performance from the O.S. FS-70, probably because the carb is more in line with fuel tank centerline). Then I cut the mouthwash jug for length and began slowly Dremel-ling out the openings with the sander drum tool. The paint is good, old Rustoleum spray rattle-can, off the shelf. I lucked out and it happened to match the covering perfectly. I finished it off with the red monocote trim to match the plane.
Almost always gets nice comments at the field, especially from T2 and T60 afficiandos...
Hope this helps...
-- Rod
Hope this helps...
-- Rod
NJ
RE: Tiger 60 Cowl ?
How did your tiger 60 perform with the OS 70. I currently have a saito 72 and waiting for the tiger 60 arf to come in. I have read a thousand post where people are putting saito 100's and saito 91's in this plane to get good performance. Do you believe there is a need for such a large engine in this plane. I'm confused, I have a saito 100 I could put in the plane, but would rather install the 72. Let me know how performance and flight time was on your setup.
WA
RE: Tiger 60 Cowl ?
Thanks for sharing your Cowl. That does look good. A Cowl does
so much for a plane.
The other poster asked about a Saito 72 on this plane. I can say
that the 91 had plenty of extra power. I haven't gotten totally comfortable
with the plane yet but I can tell I can hover it.
RE: Tiger 60 Cowl ?
My saito 91 hovers my T60. but if you wat kE or much rudder athority at all you need to build a larger ruder. it seems no matter how much thrust i have the thing wont KE for long.
OR
RE: Tiger 60 Cowl ?
ORIGINAL: chem16
I've seen a few Saito 72's at the field and I'm under the impression that the FS-70 has slightly more power, although I've got no scientific proof of that. Either engine should fly the plane well. It's a great plane for all around flying.
Good luck...
-- Rod
