Large Control Arm/Bellcrank needed
Old 08-12-2002, 12:28 AM
Birddog-RCU
My Feedback: (62)
Default Large Control Arm/Bellcrank needed
I need a large double sided control horn that can attach to a rod with a set screw. The rod controls the rudder on a 1/4 scale plane and I need to arm to set up a pull-pull system. Where can I find these?
Old 08-12-2002, 03:21 AM
rcpilotsteve-RCU
I know Dubro sells a large servo control horn. Is this what your after?
A long and strong enough horn to connect a rod to!
Old 08-12-2002, 03:30 AM
Birddog-RCU
My Feedback: (62)
Default Control Arms
I guess it can best be described like the double control arm on a servo but for use attached to a rod. I need a larger one to get more leverage for large applications on 1/4 scale planes.
Old 08-12-2002, 03:58 AM
rcpilotsteve-RCU
Could you use a brass bar.
Glue up a base for the brass, mount the the brass with a bushing to the base. Run control rods from the Servo to the brass bar. Then from both outer edges of the brass bar connect your pull pull links and run them out to your control horns. Use two 1/4 scale T horns on the control surface, match them back to back instead of using the back plate.
Am I on the right track
Old 08-12-2002, 04:03 AM
ProfLooney
Default control arm
Try gator rc or nelson hobbies both have unusual control horns etc
Old 08-12-2002, 04:04 AM
Birddog-RCU
My Feedback: (62)
The rod that controls the rudder is internal (for scale look) thus the need for attaching to it. Seems like I've seen these before but just can't remember where. The device would be like a bellcrank but 180 instead of 90 degrees.
Old 08-12-2002, 04:13 AM
rcpilotsteve-RCU
Well I'm way out on this one. Sorry :stupid:
_____________________________________
Old 08-12-2002, 11:17 AM
Jemo
Jemo's Avatar
Is this what you are talking about, this one is from nelson hobbies
Old 08-12-2002, 11:47 AM
Birddog-RCU
My Feedback: (62)
Default Control Arm
Yes but attached to the other end of the plane... the rudder. It would need a set screw to be able to attach to the rod which accuates the rudder.
Old 08-12-2002, 12:00 PM
Jemo
Jemo's Avatar
Do a search for rudder control horns, here's a couple
http://home.earthlink.net/~surelink1...horns_pic.html
www.swbmfg.com
Old 08-12-2002, 12:35 PM
Birddog-RCU
My Feedback: (62)
Thanks for the link but this is not something that attaches to the control surface. The rod that accuates the rudder is internal and looks more like a bellcrank but 180 instead of 90 degrees and uses a set screw to afix itself to the rod.
