Fuel flowing with Starter Box.
How do you get the fuel flowing with the starter boxes? After I got the battery and screwed everything in I popped my Losi XXX-NT on it. It makes a starter noise of sorts, but I don't see any fuel moving. I also don't have my pull starter on there because the screws stripped out. Is that hole going to cause problems. I imagine it leads to the cumbustion chamber but I'm not sure.
VA
RE: Fuel flowing with Starter Box.
Plug your tuned pipe with your finger while turning over the engine.... You will see the fuel flow (unless you have an air-leak somewhere) to the carb; careful not to flood it.
