Antenna Tube?
KS
Antenna Tube?
I need an antenna tube for a kit im building and I do not want to spend 6.25 for the sullivan pushrod idea..anyone know where to buy some plastic tubing by the foot the size of the nyrod stuff?
RE: Antenna Tube?
I used a strip of coreflute, the plastic corrugated plastic sheeting of SPAD fame, in my last model. Just cut down a strip leaving one complete section. Cheap as chips.
RE: Antenna Tube?
If you have a friend in the medical field-IV tubing works great-all the other gizmos included can be used in all kinds of places. Just be sure to get an unused one. Flipstart
RE: Antenna Tube?
OK. I finally found the item made by DuBro.
It's called Antenna HOUSING. It's 36" long.
Other manufacturers sell Antenna Tubing for cars which is more like 12".
Looks like Tower sells the DuBro item only in bulk, so you can get 24 for about $20.
Best bet is to go to your Hobby store where they probably will sell you single ones at about 0.80 - 1.00 each.
Exeter_Acres,
What aisle should I look in to find the plastic tubing? Haven't seen anything that small.
Exeter_Acres,
