Ultracoat Question
Can someone out there tell me how to apply Ultracoat trim pieces? By this I mean like the way you can apply monocoat by spraying it with windex to activate the adhesive and then applying it like a decal. I know trim solvent works, but it dissolves the paint I'm trying to put the ultracoat on, so that's out. Any suggestions would be appreciated. Thanks, Andy
Yes...you can use the windex method.... as far as I know.... place the trim...gently squeegee the water out and let dry for at least 24 hours.... then if needed you can tack down the edges with your iron on low.....
