Honeybee 3D replacement blades? (carbon)
My Feedback: (69)
AR
Does anyone know if there is a set of carbon fiber main blades that will work with the esky honeybee 3d heli? Cant seem to find any.
OH
RE: Honeybee 3D replacement blades? (carbon)
If I knew the length of the space in the blade holders, I could see if they match those from my pic pro, which also fits hornet blades, then Helihobby has many carbon blades, even mah blades...
I use main blades from my Ms Hornet II on my Esky,
I think the carbon blades from Dragonfly 22# will do the same.
It can fly a lot better in the wind..
Hadi
Hadi
PA
If the blade root thickness is less than the blade holder opening, you can always use the washers. We do that all the time with gas heli.
