what is the name of this heli?
Hi all
I found this helicopter but i dont know what it is:
[link=http://www.rc-expert.com/plane/h-feda-eskyrc.htm]http://www.rc-expert.com/plane/h-feda-eskyrc.htm[/link]
Any one know what it is? any experience or opinion about it?
is it good for beginners?
That is the first copter I bought. It is basically a hummingbird clone.You will need a main shaft collar after a while because they hold the shaft in place with rubber tubing which doesnt last long. I would also get a head stiffener for the main blades.The radio seems decent but the e-sky servos in it would not respond at times for me. I replaced them with hitec hs-55's and everything is fine now.I didn't see a price but mine was 199$ with the crash kit and sim.
A hummingbird elite series is a much better setup but that one would be fine to learn on and less expensive than an elite. It is also a very tough copter. Although my elite flies a litlle better the feda dragonfly takes abuse much better if you crash alot.You can replace your struts with coat hangers when they break![Wink](images/smilies/wink.gif)
EDIT: I just looked closely at the pics and it looks like they already changed the servos I got with mine. Maybe they figured out the esky servos were no good. They also moved the receiver which I also had to do and they use a different receiver. It appears they fixed quite a few things since I bought mine. I didn't get mine from RCexpert either.I also got only one battery and one canopy.
OH
It looks to me like a mini dragonfly as well, and I agree with RCelectrichelinut. Looks like a good FP to learn with. Depending on batteries and such, the tail motor on it tends to fry fairly quickly, helihooby sells the high authority motor which would be a good replacement when the first eventually fails.. Happy flying....
Thank you guys for replying.
the price is $190 for the heli+airwolf hummingbird body without wheels+training kit
+crash kit + 2 liion batteries + $35 shipping. total=225
i have another question, is there a micro heli that do 3d and can be used with the airwolf hummingbird body?
