what turbine yellow f-16?
My Feedback: (31)
RE: what turbine yellow f-16?
P-80 Wont barely fit in the hatch. I had a P-70 fitted in mine. Fit was good and a lil bit less weight. More than enough thrust. I saw one fitted with a artes super bee at the az jet rally. Thing flew like it was on rails, quickly too! IMO, You could definetly go with one of the 14 pound mini's.
My Feedback: (10)
ORIGINAL: chrish
what turbine has worked good for converting the yellow f-16
is a p80 overkill?
everyone seems to be running jetcat
thanks, chris
is a p80 overkill?
thanks, chris
Hi Chris,
I have seen a P-80 powered BVM F-16, I would not recommend it, too heavy and not enough room for fule.
My Feedback: (57)
I've thought about this one for a long while, and after consulting with a jet jockey the P-70 is the best choice, with the latest version I think pushing 17 lbs. No way I would use a P-80 in it, too much power and too much fuel required.
Wren 54 is my second option.
David
David
My Feedback: (9)
Nothing ruins a great flying jet like the Y/A F-16 than high wing loading. There are many nice 12-14lb. class turbines out there, e.g. Artes JF-50 Bee, JetCat P-60, Robart's Funsonic, Simjet 1200, PST 600R, FTE-500, etc. Also, turbine weight is only one of the factors to consider. Another factor is fuel consumption. The more efficient turbines will require less onboard fuel, thus less weight. Personally, I like the Aftes JF-50 Bee and the JetCat P-60 for your application. Good Luck!
