CG Ultimate arf help!!
I just bought a used Ultimate ARF from C.Golberg with out a manual!
Can somebody help me with the C.G., and elevator, rudder and ailerons trows?
IL
C.G. for Goldberg Ultimate Bipe ARF
"To determine the Center of Gravity, measure back on the fuselage 2 3/8" from the leading edge of the bottom wing. The C.G. range for this aircraft in 1-7/8" to 2-7/8". Ti is recommended that you balance this model upside down."
From my instruction manual.
SearchMan
SearchMan
IL
Setting Control Surface Travels:
Aileron: Gentle= 10 degrees, Aerobatic = 12 degrees
Elevator: Gentle= 12 degrees, Aerobatic = 14 degrees
Rudder: Gentle= 15 degrees, Aerobatic = 23 degrees
The manual suggest that you start by flying this model with the High rates set at the Gentle settings and low rate set at 75% of the Gentle settings.
Hope this helps,
SearchMan
Hope this helps,
SearchMan
searchman:
thank you very much, if you ever come down for vacations to Cabo San Lucas in Baja Mexico, you will have a plane to fly on Saturday!!
gracias!!
gracias!!
