Dragonfly FP electronics to honeybee FP?
Hey guys, I have a honeybee fp with motor and batt and charger only. I have the oportunity to purchase a used dragonfy in good shape. It looks identical to the honeybee. Can I swap over the gyro, mixging board,servos, reciever, ect? will they fit? I priced the items that I need at the local shop but it will cost more than buying the whole combo. Thanks much!
Most of the clones are nearly identical in basic design and contruction.
You might have to move the electronics around a little depending on which frame you deside to go with, but otherwise there should be no problem.
