P-38 Construction Project
MO
I'm working on a P-38 Lightning and I thought I would share the process if anyone is interested. Before beginning I
searched a lot of posts here and they have helped tremendously, I thought I would return the favor.
The plane was developed by a friend who was considering selling it as a kit. He made about 4
and I picked one up after seeing how nice his prototype was.
It is roughly the same size as the Royal kit, with a scale wing of 76".
The 2 booms, center wing and pod are all one piece of epoxy/carbon fiber composite construction with an aluminum wing spar tube.
Wings are sheeted and glassed foam.
MO
Power was the biggest question I had for this model. I searched a lot of posts to see what people have put on their Royal kits. The prototype has
a pair of OS .60s and flies great, although it is a little over 14lbs. I wanted plenty of power, but wanted to hide the engines as much as possible
to keep a scale look. I decided on a pair of Saito .82 four strokes. They weigh almost a pound less than a pair of .60s, and only a couple of ounces
more than a pair of .46 strokes. With them inverted, only a very small opening is needed on the bottom of the cowl for the valve covers.
I'm also building it with an 80" wing, which is slightly larger to help the wing loading.
I spent a lot of time researching methods of fowler flaps, as I wanted the scale look as well as the increased lift for landing this notorious bird.
Through helpful posts and emails I got ahold of plans for fowlers and modified them to work with this size plane. These are really cool to see work.
MO
I was sweating how to do some of the key details, mainly the turbo superchargers. I found the plastic parts made by dionysusbachus and
he was kind enough to make me a set. This saved a lot of time and will really add to the look of the model.
My Feedback: (10)
IL
could you pass on some info about where I could get some plastic parts for my royal p-38??? I can't seem to find any contact info for Dionysusbaccus... is he still hiding
? Thanks.
![EEK!](images/smilies/eek.gif)
MO
Yes he is hard to find. I'm not sure he is on the board anymore. He sells them on Ebay occasionally. You just have to check every so often.
MO
No website that I know of. You just have to check ebay. He puts them on there every so often, I guess I got lucky.
Isn't the KMP a larger model than the Royal?
I have got a Great Planes P38 Profile plan it has Two size 25 motors. I would like to get the plan enlarged to take two size 40 motors, Is there any formula or any measurements I can make to get the plan enlarged.
My Feedback: (27)
SC
Hi ab,
To enlarge your plan, just go by percentage. Say you have a 50" wing and you want a 75" wing. Simply increase everything by 50%...............lengths, widths, heights and material size. For a profile P-38 with a pair of .40's, a wingspan of 75" to 80" would be good.
Al
Al
ORIGINAL: dannost
I'm working on a P-38 Lightning <<snip>>The plane was developed by a friend who was considering selling it as a kit. He made about 4 and I picked one up after seeing how nice his prototype was.
Dave Olson
MO
I stuck everything on the scale last night to see how the weight was looking. Without a few servo extensions
and the Flite-Metal covering it is 12lbs-10oz. I'm guesing it will be around 13lbs, maybe slightly more.
This will yield a wing loading of about 41oz/sq.ft.
Can anyone compare this with their Royal? With all four fowler flaps it should help greatly
on landing (I'm hoping)
ORIGINAL: michael_car
Hi, are any of the P38's still available? Where can I get one? I am very interested. Thank You, Mike
MO
Michael,
My friend has given up on mass producing the kit due to the time involved. He does have a couple left. Send me a PM or email if you are still interested.
Mike The wing P-38 is still in production, 70 inch span and works very well with a couple of .46's.
http://www.wingmfg.com/
MO
Here are a couple more of the inboard flap. This section is part of the fiberglass fuse, so I have a much bigger access hatch, which makes
for a better picture.
CT
I just wanted to tell you that your P-38 looks GREAT and you should check out TWINMANS article, its very informative.
Good luck and I hope you post some pictures of it in flight
Ron Randall
http://www.rcuniverse.com/forum/Meta...1870990/tm.htm
Ron Randall
Mark:
Only four years old? That's still a new airplane. I have one still in excellent flying condition that's well over 40 years old. My Tiggerkitty twin (see avatar) is about 13 now. Several of my others are more than 10 years old. My oldest Duellist for example.
I have to be careful about getting new planes - I just don't have a lot of room left, and (no brag) I seldom crash one. Last major damage was three years ago now, parts scattered for more than 100 yards. Then I fixed the blasted thing when I could have had room for a new one.
Bill.
Bill.
MO
Metal,
What twinman article are you referring to? The link in your post is for your thread on you metal process.
And thanks for sticking that picture in front of me again. I can't possibly hope to compare (LOL).
I will say I am having a lot of fun doing my first scale project. I have learned that next time I will
have to do a larger plane, I think it would be a lot easier to make scale details.
How do you guys ever get the nerve to fly them? Picking a twin for my first was probably not a
good idea, but I got the plane from a friend so I went ahead with it.
dannost:
I think metal is talking about TwinMan's treatises on twins and P-38's on rcwarbirds.com.
Bill:
Four years is an old P-38, unless it's a hangar queen, which mine are not. The Yellow has flown at least once per year for the last 4 years. As you say......Haw!
mt
Bill:
mt
