Dubro or Rocket City-What goes where?
I'm sure this is unimportant, but with the hardware pack supplied by WH, there are 2 sets of Rocket City horns, and 1 of dubro.
Does it matter which set goes where?
Hiding the mounting screws is easier with the rocket city.
Any advice from the guru's is greatfully received!!!
RE: Dubro or Rocket City-What goes where?
thanks both.
That was my thinking, but the thoughts of a madman tend not to carry too much weight!!
The Dubro horns should be shortened so the pivot lines up with the hinge line, this will give you correct geometry and plenty of throw. You can make them shorter too if you don't care about the geometry.
TF
TF
