H-9 T-craft
Banned
H-9 T-craft
I have a g23 Glow on mine....I make my own fuel....$2 gallon......No worry about mag or electronics from engine giving your rx fits.
I am very happy with it. $200 and go,
Doc
Doc
Banned
Gas and glow
There is some drawbacks to gas not mentioned..
Other than the ones mentioned already......You have "gasoline to smell in your garage and car to deal with... I would suggest if you go gas..you use a siphon hose to draw from your auto tank and mix each day you fly....gas will get stale quick....The remainder you have left over at the end of the day...just toss it back in the car tank...It will not harm your vehicle The biggest is no knowing the drawbacks of setting up your airplane because of the engine electronics.....switches, throttle rods, have to be monitored carefully on placement.......this can play havoc on your rx if not careful...I mix my oil and meth......it is very inexpensive....
The glow is powerful, and the weight does not look for Jenny Craig shops.
It is about $85 cheaper.....That savings alone will buy me a lot of fuel.
The T-craft is a very respectful airplane.
I detailed my cockpit with the insturnment panel from hanger 9 and it looks wonderful ($18)....
I used copper tubing to make my stick and shrink wrap for the hand control........Colored stick pins made the throttle, mixture etc.
I placed a red ball stick pin in the tubing on the stick, and then wrapped it with the shrink...I chose NOT to use a pilot.....I painted the interior for orginality.
Good luck guys...
Doc
Good luck guys...
Doc
OK
Gas engine
Hello,
I would say go with the RCS 1.4 it would be a great engine for this plane, I love mine. YOu can check them out at www.rcsshowcase.com
Banned
Whinny 2 stroke
Hey sport.........The g23 glow is far from whinny.....!
When have you last heard one??
You can count the blades at idle, and performance is great.
Just what four stroke would you recommend.....? I will assume money is not a factor.
Do you have a t-craft??
DOC
DOC
Banned
$ stroke
Sport,
You are sooooooooo right the 4 strokes do have "the" sound.
I have a t-34 w/ a saito 4/s and a 3 bladed prop.....It sounds like anything but a r/c aircraft.
DOC
DOC
Banned
FUEL
To make fuel is rather simple.
Go to any speed shop that sells the Meth (alcohol) and add 5 ozs of oil per gallon.
Take your own approved container and add your oil at the shop...Tell them to fill er up!
About $2 per gallon plus oil....A 1 qt. can of oil will make about 6 gallons for around 8 bucks.
Nitro is not needed for the g23 glow.
Good Luck,
DOC
Good Luck,
DOC
Banned
H9 Taylorcraft
Rcbuilder,
Hi....Yes it is a beautiful model.
You might check the pervious posts in this forum.....I made a few adjustments on mine....It is a beautiful airplane.
Regards,
DOC
Regards,
DOC
Banned
H9 t-craft RCBUILDER
Nothing spectular......I dressed the cockpit as stated above and put a g23 glow onboard.....My airplane isn't special.......There are just a lot of varibles that can come into play.
This kit is expensive for an ARF.....I chose to go "medium" cost....It still did not turn out that way.....It is too pretty to go medium.
Regards
DOC
Regards
DOC
Banned
review
Paradox,
Have you loked at the review on horizon hobby...It gives an example of two different engines used.....You may find the info useful to find your engine..
Good Luck,
DOC
Good Luck,
DOC
Banned
Your engine
I don't know of any other way to help you.
As I have stated before. mine has a g23 glow. I don't know what a 120 will do..........Try it.
DOC
DOC
Re: Yes I know about it
Originally posted by Paradox
but that them and I always want some real people, suggestions.
Re: so you think a 120
would be underpowered? I was thinking the same but still do not know
But, Horizon says this thing is capable of just about anything... so I want to have a motor in it that will allow exploration of that claim.
H9 taylorCraft ZDZ40 or Moki2.1
If you are mixing your own fuel be aware you must use oil that will mix with alcohol. Most mineral based oils will NOT mix with alcohol. Castor and most synthetics (like KLOTZ) will.
Also BE SURE to use enough oil if possible check with the manufacturer before using your home brew.
Banned
Your Family....
So let me figure this out here......You dance, go to school, work, fly RC , build, and read when you have the spare time....
Your family started flying in 1980......When did you start flying?
Are you a member of the AMA???
What club do you fly ...?
Doc
Doc
Thank You for asking ,Joe. I 'm sure you were able to understand.
As you can see,it is better to engineer chemicals than abuse them
TN
Everyone lets just calm down some. Remember, anyone who has a computer can read this website, regardless of age or anything else, so lets try to keep it friendly.
I did finally put mine together with a ZDZ-40. Having a light gasser on the plane sure is nice... but it really is capable of totally overpowering the H9 Taylorcraft. Something a little smaller wouldn't be bad at all. Again, smoke is a must.
